IT moved all of our projects to a new directory and have subsequently broken all the survey events. Is there a way to update survey events so they can find the original file again or does each event need to be redone to fix this?
e.g.
I brought in a fbk located at p:/prj/6000 that file is now located in p:/6000
I don't know of a way to fix them all at once, but if you right-click the import event, Properties, you can reset the file path for individual events.
HTH
AWood
I tried that and it doesn't work.
I right click the specific event, select properties and the only two fields I can edit are "Name" and "Description". The "File" entry is not editable, but it does have a browse icon, but if I click that icon it tries to open the file and of course it can't find it.
