Civil 3D Forum
Update Field isn't updating as expected
12 REPLIES 12
Message 1 of 13
neilyj666
966 Views, 12 Replies
I have a field in a block and all the FIELDEVAL variables are set as shown in the screenshot but the field doesn't update on REGEN - I have to issue the UPDATEFIELD command to update the field.
There was a previous thread started in March 2011 with the same problem - is this another unresolved bug??
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
12 REPLIES 12
Message 2 of 13
Alfred.NESWADBA
in reply to: neilyj666
What field-type is it? If it's a save-date/time or plot-date/time then it would/should not update with a _REGEN.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 13
neilyj666
That was my initial thought but It's just a simple DATE field
Message 4 of 13
Alfred.NESWADBA
and how did you get it now to "2013"? Have you defined it new or saved or what happend? In the last screenshot it was 2012.
If you have the old drawing, can you delete all but this block and upload it so we can play with trying to update it (I can test it with Civil3D, Map3D, AutoCAD all 2013 if necessary).
- alfred -
Alfred NESWADBA
Message 5 of 13
neilyj666
I issued the UPDATEFIELD command and selected the block
Message 6 of 13
Alfred.NESWADBA
OK, I tried it in a new drawing and ... yes, same issue, a _REGEN does not update that "DATE" field (not with Civil3D 2013 SP1, not with AutoCAD 2013 SP1.1).
That brings me to the question: what does the field "DATE" represent, if it's not a save-time and not a plot-time ==> whatfor is it needed or whatfor is it designed?In the help I have not found it.
For me: now I know why I have not had that problem yet: because I never used it; I used SAVEDATE or PLOTDATE and they work without any issues (yet).
But sorry to have no solution for you, - alfred -
Alfred NESWADBA
Message 7 of 13
neilyj666
Indeed - as it doesn't seem to update on open or save either - only manually after UPDATEFIELD.
I have raised a support case and will post the response when (if) I get one
Message 8 of 13
ericcollins6932
I'm guessing this is functioning as intended? As opposed to editing the date, issuing updatefield populates it with the current date.
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
Message 9 of 13
neilyj666
in reply to: ericcollins6932
It seems that this behaviour is indeed as intended - from Help
"...The Date field is updated by UPDATEFIELD, but it is not updated automatically based on the setting of the FIELDEVAL system variable..."
I only need to bother with this field update every January but another example of inconsistency in the workings of Civil 3D...??
Message 10 of 13
ericcollins6932
Ever use a diesel expression for date? See forum posting attached. It might be a serviceable workaround.
http://forums.autodesk.com/t5/AutoCAD-LT/Inster-a-field-to-show-the-current-date/td-p/3356011/page/2
Win 10
16 GB RAM
Civil 3D 2019
Message 11 of 13
@Alfred.NESWADBA wrote:
what does the field "DATE" represent, if it's not a save-time and not a plot-time ==> whatfor is it needed or whatfor is it designed? In the help I have not found it.
I use it in out TB. But the first time the drawing is issued, we convert it in to static text. I don't want it to change every time the drawing is  plotted or saved. I want it to represent the issue date. The plot date is a separate field in our custom plot stamp.
Allen Jessup
Engineering Specialist / CAD Manager
Message 12 of 13
Well, that makes sense!
Thx, - alfred -
Alfred NESWADBA
Message 13 of 13
Oh! I never meant that to happen!! Smiley Very Happy
Thanks for the comment Alfred
Allen
Allen Jessup
Rail Community
