Active Member
tjshaffer
Message 11 of 15 (544 Views)
Re: unselectable/disappearing viewports
10-26-2012 08:53 AM in reply to: demus72
Unfortunately, this still happens to me too.  After repeatedly trying different work-arounds I found this to be the easiest way to select my vport: 1] select the Pspace tab you need to be in  2] in 'Properties' palette click on 'Quick Select' at top right then in the 'Object type' drop-down select 'Viewport. "Value' field is ByLayer (see attached 'Quick Select' screen shot for settings).  3] Click OK and you should see the vport highlighted with grips.
Member
lostinthought005
Message 12 of 15 (198 Views)
02-06-2014 05:43 AM in reply to: demus72
Check your layers perhaps your veiw ports where on a frozen or off layer.
Member
lostinthought005
Message 13 of 15 (195 Views)
02-06-2014 05:48 AM in reply to: lostinthought005
It keeps disappearing but i figured out it is because of my layer states keep turning off th veiwports layer
New Member
cfundyrun
Message 14 of 15 (166 Views)
02-12-2014 02:04 PM in reply to: demus72
Make sure layer 0 is unfrozen and defpoints is unfrozen.  Click into the model space tab, then back to paperspace.  Then REGEN.
Member
makatski
Message 15 of 15 (122 Views)
03-26-2014 03:03 PM in reply to: demus72
excellent. this helped!
