I am having this problem or a similar one as well. When I open up my base drawing and hit F2, several of my drawings come in as unresolved:
SOLVED! I had the same case, I run the AUDIT command which fixed like 18 errors, saved the base file, and reopen the drawing, and the ref. was loaded!!!
I am having the same problem... "unresolved" base file. The base file references itself twice in the external references. One says the file name, status:opened, lists the size etc. The other referenced file is the same base file but the status is "unresolved". The problem started when i saved it and try to open another file it was xrefed into. Then the base xref file suddenly wouldn't appear and in the external references it says "unresolved". Tried to redefine the path, unload and reload, detached and reattach, nothing. Tried to run the AUDIT command and nothing. Any ideas?
I had the same problem. The location of my file had not been changed. I tried auditing and recovering and it still said "Unresolved, File may need recovery." So I changed the name of the file being xref'd and updated the location of the referenced file. It then located the file and xref'd properly.
Hello All,
Had the same problem as posted here, XREF was unresolved in all drawings that it was refernced to, tried to Detach and Attach but only got the error "Invalid". Went to the base file and lo-and-behold, it was XREF'ed to itself, and this circular reference would not detach!!! Used the above workaround whereas the bad XREF is pointed to an empty drawing, this worked but the CAD Yoda here was not satisfied with that. After many toiling minutes, Yoda purged the Blocks from the drawing and then the Baad XREF would detach!! There you go.
I just installed this Autocad 2015 hotfix and it worked.... xref loads perfectly
I pathed the 'unresolved' xref to another dwg file, then back to the correct one, and it removed the 'unresolved'--because as usual, quirky CAD dumped by background from all the plan views, for no reason whatsoever, then refused to 'resolve' the unresolved'--until the fix above.
