Afternoon,
Bit of an odd one. I have a number of drawings, Civil 3D and otherwise, where panning and zooming in paper space is incredibly laggy. When I enter a viewport, the bottom right of the status bar flashes rapidly with 'unrecognised' for about 2 seconds then disappears. It occasionally does it without entering a viewport too. See image below. I suspect it's to do with coordinate systems. Any ideas? and how do I sort it out?
Cheers,
Kevin
Could be this, from the 2014 Map 3d Readme file.
Coordinate Systems
The AutoCAD GEOGRAPHICLOCATION command is not supported in Map unless the geo-marker is setup with a Longitude/Latitude value of (0,0) and is positioned at the location (0,0,0) with a North direction equal to 0.
If a geographic or arbitrary coordinate system is assigned to the Map, it will not be supported by the AutoCAD GEOGRAPHICLOCATION command, which only supports projected coordinate systems. This command will then behave as if the Map is not geo-referenced. As a result, the geo-marker field in the main status bar will display “Unrecognized” instead of the coordinate system name.
Thanks Jay, looks like it could be that. We don't use Map so seems odd it'd arrive out of nowhere.
Any ideas how to resolve it?
Kevin
Try, Drawing Settings > Units & Zone tab > Zone > No Datum, No Projection.
