wht do I get unknown command "aecccreatealignment" when I have civil 3d and companion land desktop?
Solved by Alfred.NESWADBA. Go to Solution.
Hi Van,
What software are you using?
If you are getting a message like that most likely is product of a bad install, please run a reinstall of the software from the control panel.
+ adding to Tatiana:
What profile is active? If you run Civil3D with the profile "as AutoCAD" then the AECC-commands are not available.
- alfred -
