A quick search didn't reveal anything on this, but I thought I would post this anyway. (C3D 2013 SP2)
The problem I'm having is all of a sudden, ONE drawing out of several that I may have open stops responding, and then if I switch to any other currently open drawing, I can zoom and pan with the mouse, but any other command - no matter how initiated, returns UNKNOWN COMMAND. Example below:
You can click the "X" on the document and it just says UNKNOWN COMMAND "CLOSE"
You can click the "X" on the application and it just says UNKNOWN COMMAND "EXIT"
So you have to use Task Manager to close Civil 3D, and of course lose any unsaved work.
It seems like this has started happening more often after installing SP2 for C3D 2013.
I'm sending in the CER's.........
Randy, what if you open a new drawing, then insert this drawing exploded. Does the error go away?
It's not a drawing problem, it's more of a system problem.
This happens at random times with a variety of projects/drawings open.
@Anonymous wrote:
What happens if you redefine any of those commands? Just wondering if someone's place a hacro in your system.
This is a system error, not a rogue macro or something.
To restate, when this occurs, you cannot initiate any command via any method, including "redefine"
Eventually, after you switch drawings (using CTRL+TAB) a few times, it will finally give up and return a fatal error.
Rick Jackson
Survey CAD Technician VI
The program crashed when you see this. I am suprised at the suprise with this error. 🙂
When I see this all commands produce the same 'unknown command' response. I have found no way out of it. At this point the work is lost from the last save or autosave.
If autosave is on DO NOT close the program. Browse to your win temp folder and rename the autosave file, if it exists...
John Mayo
I think I first saw this in 09 or 10. I think there are also older posts here on this topic.
Seeing this happen to only one file is a bit new to me. When I see this in one file the others open in the same session also produce the error. Do you run multiple instance of C3D or are all files open in one session?
John Mayo
John, what I meant is that one file (out of maybe 6 open, in ONE session) will stop responding.
What I mean by that is that only the windows cursor appears, you can't gain focus in the drawing window...
Then when you switch to a different drawing (in that same session), it acts normal (you can see the normal crosshairs), but none of the commands work - in ANY drawing
I know exactly when it happens because of the initial drawing that "stops responding".
The STRANGE part about this situation -- is that usually when a drawing locks up, the whole application locks up and you can't do anything. But in this case, you can still switch drawings freely and zoom/pan around in them with the mouse....?!?!
Thanks for your comments.
Even this happens randomly in C3D 2012 also.
In an opened session of AutoCAD ,after 4 or more files opened , switching between the opened drawings sometimes brings this issue.
And after some time the program crash.
This isn't just with Civil 3D. We're running Mechanical 2014 and regular 2014.
Had this happen a couple of times on a system I administer a few months ago and thought it may be something the operator had done. Now my own system has started doing the same.
My support company claims never to have encountered this problem, but the web has comments about this going back to previous versions. They suggested a clean re-install, like I have nothing better to do with my time!
It's becoming a major problem now that Autodesk needs to resolve.
Had this problem a couple of times last year on a couple of systems and it was really annoying. The last week I'm getting it on a daily basis! I contacted our Autocad vendors service departmant and the guy I spoke to had never come across this issue before. He suggested the usual...have you tried re-installing Autocad?
Well, I tried that and I really have better things to do with my time than keep re-installing software.
Autodesk needs to address this problem. It's not like this is some cheap cd writing software or something. My company and others spend thousands of dollars every year and we need something reliable. Otherwise, Autodesk is gonna start loosing people to other cad software.
Try
(setvar "savetime" 1)
I've also encountered this error on Civil 3D 2010-2014. When it happened today I thought I'd challenge the assumption that it disables all methods of command execution. Turns out it will still process LISP statements. I tried using the (command "save") first, but I didn't really expect it to work, and it didn't because that just enters the save command at the command prompt as if I had typed it in myself. It's been a while since I did much LISP, and I couldn't remember if there are any other ways to execute a command. However, I had turned off autosave earlier in the day because I was working in a drawing with large images and millions of pline contour vertices, so I tried the above, and the drawing immediately autosaved. It gave a fatal error about a minute later, but by then I had confirmed my fresh autosave file was a valid dwg file and was good to go.
David
It just happened to me. Here is a paste of what it did before crahsing. I was not doing anything special. Just going from layout to layout and plotting. I work with Civil3D 2014 the french version. I had the chance the program autosave just before. I did not lose too much work but still...
Commande: Spécifiez le coin opposé ou [TRajet/SPolygone/CPolygone]:
Commande:
Commande:
Commande: _copyclip 2 trouvé(s)
Commande: *Annuler*
Commande:
La discipline CIVIL est activée.
Enregistrement automatique vers C:\Users\ValoisA\appdata\local\temp\LAVV1-00222149-C01@C05_L-12169-M_1_1_6671.sv$ ...
Commande:
Commande:
*Annuler*
Commande: *Annuler*
Commande: Commande inconnue "LAYOUT_CONTROL". Appuyez sur F1 pour obtenir de l'aide.
Commande: *Annuler*
Commande: *Annuler*
Commande: *Annuler*
Commande: *Annuler*
Commande: *Annuler*
Commande: *Annuler*
Commande: *Annuler*
Commande: *Annuler*
Commande: '_VIEWPLOTDETAILS Commande inconnue "AFFRAPPORTRACE". Appuyez sur F1 pour obtenir de l'aide.
Commande: _QSAVE
Commande inconnue "SAUVERAP". Appuyez sur F1 pour obtenir de l'aide.
I have no solution either to offer. The wizard in IT had no solutions. It seems to be something we need to live with.
