I can't deal with a problem with fatal error Unhandled e06d7363h exception at fe359e5dh.
I use Civil 3D 2012 and Ferrovia - railway design solution (supports AutoCAD Civil3D).
The problem occurs in different files, which are created earlier and now.
Error occurs mostly when I'm running a specific tool (design grade line on the profile). When I try to import profile from Civil 3D to Ferrovia the same error occurs. Now, fatal error appears when Civil is starting.
I didn't install new programs, just updated Civil 3D (after error); restore system - problem still occurs
Civil 3D 2012, Windows 7 64 bit.
Intel 2.8 GHz, 6 GB RAM, graphics AMD Radeon HD 6700 series.
In my opinion resources are not much burdened.
I'll be grateful for help.
Martin
If you're on Subscription I'd start a Support Request (or call if you're Gold level). Also reach out to Ferrovia.
Try reading these and see if any apply to your situation http://forums.autodesk.com/t5/forums/searchpage/tab/message?sort_by=-topicPostDate&solved=true&q=e06...
Allen Jessup
Allen Jessup
Engineering Specialist / CAD Manager
