bcales
Message 1 of 11 (2,640 Views)
Undo has been disabled...
2640 Views, 10 Replies
05-09-2012 01:07 PM
Undo has been disabled in order to prevent undo file overflow...
Is there anyway to increase the Undo capabilities.
mathewk
Message 2 of 11 (2,617 Views)
Re: Undo has been disabled...
05-09-2012 05:17 PM in reply to: bcales
I've never seen this. How about saving and closing the drawing and reopening it?
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
sboon
Message 3 of 11 (2,612 Views)
05-09-2012 06:53 PM in reply to: mathewk
I've seen it fairly often, especially while doing a lot of corridor section edits.  I think that there's a way to turn off the undo function and then turn it back on again.  When you do that the program apparently starts a new file.
Jeff_M
Message 4 of 11 (2,604 Views)
05-09-2012 08:42 PM in reply to: sboon
SBoon wrote:
... I think that there's a way to turn off the undo function and then turn it back on again. ...
Undo, Control, None or One
Undo, Control, All
oceanside
Message 5 of 11 (2,204 Views)
01-09-2013 01:17 PM in reply to: bcales
I have done this so many.....times today.  It doesn't work.  Software is Civil 3D 2013.  A couple of computers have the message "Warning! Undo has been disabled in order to prevent undo file overflow.  You may re-enable it via the undo command.  The undo file length was 1768915703 bytes".  I've been using the UNDO command since Release '08 & I've never seen this problem.  I have search & search & nothing seems to work....how do you control the length of the UNDO command.  I don't understand how UNDOCTL works cause it's read only.  Does anyone have a solution?
the best is at the beach!
sboon
Message 6 of 11 (2,200 Views)
01-09-2013 01:19 PM in reply to: oceanside
Save - Shutdown - Restart the program.
clevelandw
Message 7 of 11 (1,145 Views)
10-01-2013 09:51 AM in reply to: sboon
C'mon "Experts" stop just telling everyone to "Save and Restart" Obviously, there is an issue that needs to be resolved. Put that "Expert" title to use.. Geez!
rkmcswain
Message 8 of 11 (1,140 Views)
10-01-2013 09:56 AM in reply to: clevelandw
In their defense, I would say that the suggestions offered are the best known workaround(s).
These guys are peers using the software like all of us, and do not have a hotline to the programmers / software architects.
mathewk
Message 9 of 11 (1,132 Views)
10-01-2013 10:01 AM in reply to: clevelandw
Thanks for the "constructive" criticism, clevelandw, but I don't see any usable advice from you at all on this issue.
Matt Kolberg
Jeff_M
Message 10 of 11 (1,126 Views)
10-01-2013 10:10 AM in reply to: oceanside
For C3D2013 & 2014, perhaps THIS has something to do with the UNDO file filling up.
