Civil 3D 2013 on Windows 7 64-bit:
Cannot use UNDO on command line because I have to enter the command many, many times to ever undo anything.
I therefore use the UNDO pull-down in the quick access toolbar; however, a few simple zooms and/or pans using the mouse wheel results in many, many (it seems like hundreds of them) "Group of Commands" items. I have to work my way back through (that is highlighting) many of these to ever get back far enough to undo something simple like an erase of an object. It works like this even if the erase (or whatever) was the last command issued--besides zooming and panning.
The mouse wheel zooming and panning seems to be what is adding all of the "group of commands" listings in the undo list. I must say this seems like a terrible bug in the software to me.
Combine zoom and pan IS checked under user preferences of options.
I have searched for hours looking for a solution.
Is there anybody out there that can please help or at least let me know that this is a known problem?
Autodesk--PLEASE can't you fix this?!
Thanks for any help you can provide.
Thanks.
If my company could save the money that it is costing for all the time I waste with this, I think they would have enough to pay Autodesk to assign a team to fix this. It is truly mind boggling why such a significant bug receives so little attention.
....because it isn't sexy and cutting edge enough and the marketing people couldn't sell software that has only had bugs fixed rather than whizz bang new features added?
There are other irritating bugs that are still present several releases after being reported
We have been having the same issue with the Undo not working correctly and I was hoping Autodesk would have fixed it in Civil 3D 2014 but it's not but I finally figured something out.
I started doing some testing with Civil 3D 2013 and 2014 and I have confirmed this with both versions.
I first started testing to make sure it wasn't our custom shortcut or our custom profile and that wasn't causing the probrem, so I then started testing our template that we make for each version and I noticed that if I start a brand new drawing using our template that the Undo doesn't work, so then I decided to use the standard template out of the box and wouldn't you know it the Undo worked and I couldn't break it. So now with the same session open with 2 drawings open using the same shortcut to launch Civil 3D and using the same custom profile I can have 2 different files open using 2 different templates and sure enough the Undo problem occurs in our drawing that was using our template but the template that came with both version works fine.
So the problem is within the file/template, which makes sense now to me because some users will say it works fine in this drawing but not in this other drawing, but now I have no clue on how to fix this because an audit/recover doesn't work, about the only thing we could do is remake our template from the standard template, bring in all of our styles and save it as our new template and then wblock stuff from old drawings into this new template, ya way to much work.
Well Autodesk hopefully this will help you and hopefully you can help us figure out what's in the drawing file that is making the Undo fail.
Brent Morris
Yes, all settings are correct.
I have done more testing this morning and I think I know what is causing the Undo to fail.
I have narrowed it down to Associative Hatching that will cause the Undo to all of sudden list every mouse zoom as an Undo command and as soon as I take off the associative hatching then the Undo command will work and will combine all the mouse zooms into 1 undo command.
Could someone verify this and see if you get the same results.
Start a brand new drawing by using Autodesk Civil 3D template "_AutoCAD Civil 3D (Imperial) NCS.dwt" which is located under C:\Users\Your User Name\AppData\Local\Autodesk\C3D 2013\enu\Template.
Save the drawing before you do anything, then just drawn a couple of lines, then using your mouse middle button to zoom in and out, then go to the Undo icon pull down and you should only see a few undo commands. Now draw a rectangle and hatch it with Ansi 31 and do not make it associative hatch yet, once done save it, then using middle mouse scoll button again zoom in and out and then go back to the undo and again you should only have a few Undo commands.
Now let's see if we can break it, now select the existing hatch and make it associative hatch, now save the drawing, now just draw a line, check undo, now use middle mouse button to zoom in and out, now go back to the Undo and in my testing you should get a whole bunch of Undo commands.
I would also be curious if you take an existing drawing that you know you are having problems with and if it by chance has hatching in it select it and see if it's associative hatch and if it is turn it off and see if that fixes that drawing.
I have doubled and tripled checked everything and with all my testing I have concluded that Associative Hatching causes the Undo command to not combine all the zoom in's and out's into 1 Undo command like it suppose to.
So now if I can get other people to test this and reply back to this post then maybe Autodesk can get to work on it to solve this problem.
Brent Morris
Correction, I meant to say Annotative versus Associative, so replace Annotative for the word Associative in my previous reply
Sorry about that.
Brent Morris
I have been able to confirm on 3 different machines that the Undo command will fail if we have just 1 hatch that is set to annotative hatch and this only happens in Civil 3D 2013 SP2 and Civil 3D 2014 No service packs.
I have tested this also in Civil 3D 2012 SP3 and the Undo works fine and I couldn't break the undo by using annotative hatching at least with SP3.
I have also tested this with ADT & MEP 2013 & 2014 and the problem only exists with Civil 3D 2013 & 2014 and only if there is just 1 piece of annotative hatch within that drawing.
It doesn't matter if the HPAnnotative system variable it 0 (off), if there is 1 piece of hatch within that drawing that has annotative hatching turned on within a Civil 3D 2013 or 2014 drawing then the Undo doesn't work correctly.
I have been able to take the Civil 3D 2013 & 2014 drawings that have this problem and change every single piece of hatching and turn off the annotative hatching and the Undo will start working for that drawing jsut like it's suppose to.
Brent, I do not know how much time it took you to figure this out, or how you did it. But I believe you have got it. Thanks for your work on this.
I deleted all hatch in a drawing (which, by the way, started giving me the undo problems only after inserting a block that has hatches in it), and now the undo list works properly!
Now if Autodesk will just fix this!!! AUTODESK, ARE YOU THERE?! ARE YOU LISTENING?!
Now I just need to figure out how to automate the finding of all annotative hatch in a drawing - so I can get rid of it and have my undo list work properly!!! It will be tedious in this drawing because I have to inserting numerous pieces of hatch at once as a block from someone else's drawing. I can't see that the FILTER command will let me select only all of the hatch that is annotative.
Sorry, my drawing actually did NOT have any annotative hatch in it. I see that the QSELECT command will allow me to select all hatch that is annotative. There is none there.
But, please note that deleting all hatch from my drawing did fix the undo list problem and allow it to start working properly.
I appreciate all of your efforts, Brent. This particular bug is a major source of frustration for me.
I am working on a drawing that has one annotative hatch that is found inside of an external reference. I detatch the reference, closed the drawing and brought it back up. It seems as though the annotative hatch may be the culprit, but will work with it more to really be sure. I will post my results as well.
Kudos may be coming your way Brent.
Using the idea of hatch being the problem, I was able to narrow down my issue to being the "dots" hatch pattern. The hatch covered a fairly large area and as soon as I changed to a different pattern, the problem went away.
Trust me. It is ANNOTATIVE Hatch, it can be in an xref and house up the undo. I agonized over this for two years. I too felt ther were no ANNO hatch int he drawing but there was one tiny peice burried in a drainage structure style. once I redefined the style I was good.
We have to be vigilant and catvh up to the legacy files xrefs and all
Joe Bouza
Definately dot pattern. I exploded the dot pattern (I hate exploding hatches) and everything returned to normal.
It is not just annotative hatches. It is also non-annotative hatches. I have two files from a drawing where I isolated all of the objects that caused this issue. It turns out that Ansi31 hatch with a scale of 20 or 21 and hound hatch at nearly all scales is causing this problem. This problem also happens when these objects are copied over to another drawing.
If autodesk is listening, here are some test cases for your bug reports.
If you're on Subscription. It would help if you started a support request and passed those drawings on to Autodesk. There's no guarantee that they'll see them here.
Allen Jessup
CAD Manager - Designer
Joe Bouza
Yes. A new template can solve quite a few problems. But it never hurts to provide some new information or to remind them what's going on. You never know it this is the time it hits somone's desk who might decide it's time to do something about it.
Allen Jessup
