Active Contributor
ad_crj_1234
Message 1 of 15 (6,799 Views)
UNDO file size
6799 Views, 14 Replies
12-18-2012 10:11 AM
Constantly getting box that says "Warning! The undo file length is xxxxx bytes. Undo will be automatically disabled at 1750000000 bytes to prevent overflow. You can clear the undo file by turning undo off and then on again via the undo command."  This is very aggravating.
Use UNDO-CONTROL-NONE, then UNDO-CONTROL-ALL, list in Taskbar UNDO empties and it works again for a short while, but then I cannot undo past this point.
This box popped up once during a command and caused Civil 3D to lock up, causing me to lose work.
Web search does not find much help.  Does anyone know a fix, how to address this, or how to increase the file length so I do not get this message?
AllenJessup
Message 2 of 15 (6,794 Views)
Re: UNDO file size
12-18-2012 10:18 AM in reply to: ad_crj_1234
Are you short of space on the drive the temp files are stored on? Have you tried clearing the temp folder.
Active Contributor
ad_crj_1234
Message 3 of 15 (6,792 Views)
Re: UNDO file size
12-18-2012 10:29 AM in reply to: AllenJessup
I had cleared the temp folder under my user name (accessed by typing %TEMP% in the windows command line), and it did not help.  However, I just found that my temporary drawing location is set to C:\TEMP.  I just cleared all files from that folder.  Do you think this will help?
BTW, Windows 7 64-bit w/ Civil 3D 2013.
AllenJessup
Message 4 of 15 (6,783 Views)
Re: UNDO file size
12-18-2012 10:38 AM in reply to: ad_crj_1234
That may be C:\Temp or elsewhere. Don't know if it will help until you try it. It's the first thing to try though.
Active Contributor
ad_crj_1234
Message 5 of 15 (6,765 Views)
Re: UNDO file size
12-18-2012 12:38 PM in reply to: AllenJessup
Thanks.  Will try and post back with experience.
oceanside
Message 6 of 15 (6,675 Views)
Re: UNDO file size
01-09-2013 01:19 PM in reply to: ad_crj_1234
So..did it work for you?  I'm having same problem...frustrating..
the best is at the beach!
Active Contributor
ad_crj_1234
Message 7 of 15 (6,661 Views)
Re: UNDO file size
01-10-2013 05:28 AM in reply to: ad_crj_1234
Actually I do not believe I have gotten this error a single time since I cleared that Temp folder.  However, I have not had to work any more in the drawing that was most troublesome for me with this error.  Presuming the occurrence of this error is not somehow related to being in a certain drawing, I may have it fixed.  I will post back if it does happen again.
New Member
TMSHELDON
Message 8 of 15 (6,150 Views)
Re: UNDO file size
04-26-2013 09:23 AM in reply to: ad_crj_1234
I am having the same error
Clearing the Temp Files will fix the problem untill the Temp file again fills up and you will see the saim error
when that happens just save your file close cad and clear the temp filder again
if i find a better solution i will post it
only happens in large files in my experiance
regards
Tom
shelmer
Message 9 of 15 (5,392 Views)
Re: UNDO file size
07-17-2013 07:28 PM in reply to: ad_crj_1234
I am getting this error on many machines in my office now (8 that I know of).  A custom temp folder is set and has been kept clean.  The undo file size is out of control though.  900+ mb and I can't see why.  The task being done are not complicated and the drawings are not huge.  Definately big drawings are worse, getting undo overflows several times a day, but many other smaller drawings have the same issue.  The undo command also doesnt seem to group commands properly even though it is set to do so in options and you have to undo many times to go back only a few steps.  Maybe this is part of the reason the undo file gets so insanely large so fast?  These are all the same types of drawing we used in civil 2011 and never had any issues with undoing or undo overflows.  Our work flows have not changed but the software is increadibly unstable in this regard.  The worst part is that the notification that your undo file is getting large often hangs the drawing, so you are forced to shut down Autocad.
Any advice beyond keeping the temp file clean?  The active temp file seems to be the issue, not all the other files in the directory.
rkmcswain
Message 10 of 15 (5,369 Views)
Re: UNDO file size
07-18-2013 05:44 AM in reply to: AllenJessup
AllenJessup wrote:
It's the Autosave path that holds the AutoCAD temp file location.
Actually, that only specifies the location for autosave files.
There is an entry a bit further down for "temporary drawing file location" (also equals the r/o sysvar TEMPPREFIX)
