While adding a vertex to a survey figure, if I click too near (like within 0.5') a survey point, the new vertex snaps to the survey point and uses its point number as the new vertex. Is there a setting for this snap feature to turn it off or change the tolerance?
Solved by INACTIVE_StaleyC. Go to Solution.
Turn off rollover tips
Run CUI, under rollover tips, cogopoints, uncheck "STYLE"
Tried unchecking "STYLE" and that had no effect. Also tried unchecking all other boxes under Cogo Point and this also had no effect - still snaps to the point. Thanks for the reply.
Just a wild guess. But try setting OSNAPNODELEGACY to 1.
Allen
Allen Jessup
CAD Manager - Designer
Tried with GRID off, no difference.
Tried with OSNAPNODELEGACY set to 1, no difference.
If you want to send me the file i can look at it for you.
TS"at"binkleybarfield dot com
In the Survey database settings under error tolerance, change the value for coordinate difference to a smaller number then try adding the point to the figure.
Chris- changing the tolerance in survey database settings had the desired effect. Thanks!
Step 1 - At the top of the survey database settings dialog, click the export settings button, and save the settings to a file.
Step 2 - open the user settings dialog, and look under "Survey Database Defaults"
Step 3 - make sure "Survey Database settings path" points to the location of your exported database settings.
Step 4 - change "Survey database settings" to the file created in step 1.
These settings will be used every time a new database is created.
