I am attempting to underline the text 'UNPLATTED LANDS' in a note label style. I want to underline the text with a hidden2 linetype. I can create a separate line and position it correctly underneath the text. I looks just fine. When I drag the text to create a leadered situation, the underline disappears. Any Ideas?
Try changing the Dragged State Components>Display> to "As Composed" on Dragged State tab of Note label style.
Text and line component stay put when dragged if set to "As Composed" but line disappears when set to "Stacked Text".
I knew about the as composed text option. The problem is that the leader will only justify to the right with the text, not both left and right.
If you just underline the text will that work or does it have to be with a special line style?
Peter Funk
Autodesk, Inc.
Did you ever figure this out? Im trying to do the same for pressure pipe, (creating labeling with undeline for first line of text) and I can't keep the leader justify..
That's what Im doing currently.. But I thought maybe there was an easier way. Thanks!
