Member
craigwsitedesign
Message 1 of 5 (391 Views)
Underground Surface Volume Question
391 Views, 4 Replies
06-28-2011 10:52 AM
Not sure if this is possible with Civil 3D, but any help would be appreciated.  I have a grid boring pattern (x,y) that I've been given wtih a top of rock and bottom of rock (z) elevation at each boring location.  I created two surfaces called top & bottom.  What I would like to do is to be able to "shade" or "hatch" the area between these two surfaces in order to show a 3d solid mass that I can view in 3d orbit.  I know how to generate the volume between these two surfaces, however, this appears as a "flat" surface when I view it in a 3d orbit.  I'd like to view this volume as a solid mass.  Is this possible?
Civil 3D 2011
Windows 7 64-Bit
Sorry the surfaces needed to be promoted for you.
Moderator - You can delete the original post with this file.
jmayo
Message 2 of 5 (385 Views)
Re: Underground Surface Volume Question
06-28-2011 11:16 AM in reply to: craigwsitedesign
If this is simply to shade it in 3d orbit then make two surfaces. One for the bottom and one that has the top surface elevations and the OUTER border elevations of the bottom. The two surfaces will appear as a 3d solid in a 3d view. Give me a min. and I'll attach a file that depicts a debris pile with surfaces.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
jmayo
Message 3 of 5 (381 Views)
06-28-2011 11:26 AM in reply to: jmayo
John Mayo, PE
IDSP 2014
jmayo
Message 4 of 5 (378 Views)
06-28-2011 11:31 AM in reply to: jmayo
John Mayo, PE
IDSP 2014
Member
craigwsitedesign
Message 5 of 5 (366 Views)
06-28-2011 12:04 PM in reply to: jmayo
Perfect.  This is exactly what I was trying to do.  Thank you. .
Civil 3D 2011
Windows 7 64-Bit
