Civil 3D Forum
Undefined Alias Referenced
10 REPLIES 10
Message 1 of 11
2960 Views, 10 Replies
Hello
I've been getting this Undefined Alias Referenced error showing up everytime I open one specific drawing.
Anyone know how to resolve this message?
Also, I'm not sure if this is related to the first part. In the same drawing I have several png files that I can't get rid of.
10 REPLIES 10
Message 2 of 11
rkmcswain
Message 3 of 11
Thanks! That worked.
I still have those pgn files in my xref manager.  All of the files are unreferenced but i cannot detach them
Message 4 of 11
Lisa_Pohlmeyer
If you use the tree view in the reference manager, are they nested in another file?  If not, can you map them to a png file that you can see and then remove them that way?
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 5 of 11
in reply to: Lisa_Pohlmeyer
There are two reference files in this drawing. Neither of the two references have the png files in them.
The saved path the png files are trying to follow does not exist on my computer.
c:\docume~1\ke229\locals~1\temp........etc
I don't believe we ever had these files therefore I cannot map them back. So is there another way of removing them from the drawing outside of the xref manager?
Message 6 of 11
troma
You don't have to map back to the 'right' file.  You can map the reference to any file at all.  (Possibly any .png, rather than any file.)
I don't know if that will help you to remove them, but there you go.
Mark Green
Working on Civil 3D in Canada
Message 7 of 11
Lisa_Pohlmeyer
that's exactly what I was trying to say.  This happens to me all the time when someone references a Google Earth image and they save that image on their C: drive.  Then when I open it, I don't have the image.  I map it to another image on my computer, then I can see it and remove it.
Lisa Pohlmeyer
Civil 3D User
Message 8 of 11
C3D_TomR
Purg any unused blocks in the drawing then try to detach the image. If that doesn't work you can then use the filter command to select all images in the drawing to erase (delete). You should then receive a message about detaching the image(s).
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
Message 9 of 11
Lisa_Pohlmeyer
Expand the details section at the bottom. You can map the saved path to a different png that you can select and remove.
Lisa Pohlmeyer
Civil 3D User
Message 10 of 11
C3D_TomR
Thanks, Lisa. I was able to send this solution to a coworker today. The Edit Alias message box was different than the typical "can't find an xref" message so it was confusing for him.
Tom Richardson
Twitter | LinkedIn
Message 11 of 11
C3D_TomR
in reply to: C3D_TomR
We later found the alias link was to a drawing that was attached via map. To remove the attachment:
  1. At the command line, type MAPWSPACE and press enter.
  2. When prompted, type ON and press enter.
  3. In the Task Pane that appears, select the Map Explorer tab.
  4. If there are drawings attached to the current drawing using map, there will be either a + or - to the left of the Drawings category.
  5. If there is a + by the Drawings folder, left click on it to expand the category.
  6. Right click each drawing in the Drawings category and select Detach from the menu.
  7. Now save and close the drawing and when you open it in the future, there shouldn't be any messages about a missing alias.
--T
Tom Richardson
Twitter | LinkedIn
Rail Community
