I have attached the file I'm working on. For some reason I lost the ability to select point grips.
Something is strange with your Viewcube in MS it's only partially visible.
Once the Viewcube was set to Home>Zoom Extents the Point Grips function normally.
Guessed you're using 2013? that's what was used.
BTW - Inserting this dwg into a clean dwt also restored the grips.
http://www.screencast.com/t/DGRKTFEBek
