1 Kudo
Post 1 of 1
UNABLE TO PUBLISH SELECTED LAYOUTS CIVIL 3D 2012
403 Views, 0 Replies
01-05-2012 07:32 AM
I'm having problems Publishing multiple layout sheets.  I select multiple sheets select publish,  I make sure I'm publishing to correct plotter, my page setup is correct, it finds no errors in status.  I then select publish.  It acts as if everything is working but it will never plot.  It just sits and spins, no error msgs as if its plotting in background.  I can plot individual sheets fine.  this is also the case when trying to plot to PDF.  tried publishcollate to 0 and 1.
I've also tried publishing 2-4 sheets at a time but no success.  I could live with plotting individual sheets if my dwg weren’t 20-70 sheets.
 any thoughts, suggestions?
Thanks in advance,
