I'm having problems Publishing multiple layout sheets. I select multiple sheets select publish, I make sure I'm publishing to correct plotter, my page setup is correct, it finds no errors in status. I then select publish. It acts as if everything is working but it will never plot. It just sits and spins, no error msgs as if its plotting in background. I can plot individual sheets fine. this is also the case when trying to plot to PDF. tried publishcollate to 0 and 1.
I've also tried publishing 2-4 sheets at a time but no success. I could live with plotting individual sheets if my dwg weren’t 20-70 sheets.
any thoughts, suggestions?
Thanks in advance,
