Civil 3D Forum
Unable to open file explorer window when select open or save from file menu
10 REPLIES 10
Message 1 of 11
64968 Views, 10 Replies
I have autocad civil 3d 2008 in my pc. From last 2 days I got a different problem i.e. when I am selecting open / save command from File menu graphical file select explorer is not opening just message in the command window . Previously I used to select files using graphical file explorer.
Any body please help me on this one.
10 REPLIES 10
Message 2 of 11
Hi all, I got it by entering FILEDIA = 1 .
Thak you all.
Message 3 of 11
Thank you for this post
Message 4 of 11
AllenJessup
If you get to the point where it's asking you for the file path and you realize you need to reset FILEDIA but you don't want to have to cancel the command. Enter a Tilde [~]. That will bring up the file dialog box temporarily and let you complete the command.
Allen
Allen Jessup
CAD Manager - Designer
Message 5 of 11
TIMKENNEDY
Sooo thankful to find this post! I was pulling out the little bit of hair I have left, trying to figure out hoe to fix this issue.
Message 6 of 11
bcitrowske
i want to know how i keeps changing on me??? this is the 3rd time i have had to look for this posted fix.
Message 7 of 11
AllenJessup
in reply to: bcitrowske
Can't answer that - But if you add these lines to [or create the file in your search path] Acaddoc.lsp. It should help.
(SETVAR "CMDDIA" 1)
(SETVAR "FILEDIA" 1)
Allen Jessup
Allen Jessup
Message 8 of 11
Thank you for this post - I had the same problem.   I am grateful.
Message 9 of 11
wfberry
Some routines within Civil 3D change parameters, particulary the filedia, and if the program crashes the routine cannot change it back to the way it was.
Bill
Message 10 of 11
Brooooo.. You're Awesome! Thanks a lot..! 😄
Thank you all.
Message 11 of 11
belam
in reply to: AllenJessup
This happened on my boss' pc today and I found your "filedia" set back to 1, fixed the issue. Thanks, because I'm the one that seems to fix his issues.
Rail Community
