I just installed Civil 3D 2007 and when I start up I get the message "unable to load catalog file 'C:\documents and settings\jim h\application data\autodesk\c3d\2007\enu\support\toolpalette\AcTMaterials.atc'"
When I look for the file I find that I do not even have a folder "application data" under "jim h".
doing a search the only file I find on my harddrive with the "atc" extention is called "mytoolcatalog" and it is in a different directory.
Any help would be appreciated.
Thank You; Jim Haddan
