In Civil 3D 2013 I am unable to import 3D styles into a drawing. WhenI select the Import button under Manage > Styles I get a warning box pop up that says "The drawing has unsaved modifications. Please save the drawings and then perform the style import again". I have clicked save and imediately after try to import the style but get the same error message. This happens on all files, including empty new files.
Solved by BrianHailey. Go to Solution.
Do you have any routines that run after a save?
