Civil 3D Forum
Unable to edit corridor sections at certain stations
3 REPLIES 3
163 Views, 3 Replies
Good Day all.
Just hoping someone can clarify a little question of mine. I have just
finished a design on a 2km access road to a residential development. I have
created property lines that show up during my section views so I can see
where my cut/fill lines are with respect to the Property line. There are
some situations where the cut/fill lines go beyond the Pline so I wish to
edit the slope criteria at these stations.
Problem is while viewing the sections and having the "View/Edit Corridor
Sections Tools" expanded at certain stations it does not show the assembly
and am therefore unable to edit any of the criteria. Any suggestions.
The section criteria is not showing up from station 0+000 to 0+150 but after
that it is fine the whole way.
Robert Howell
3 REPLIES 3
I'm not sure why your assembly does not show up in the corridor sections,
but for your daylight scenario, have you tried the DaylightMaxWidth
subassembly? You can set it to, say, 4:1 until it gets too wide (the
property line, which can be specified as your max width in logical
names).and then it gets steeper to match the pl.
Matt Kolberg
"Landman" wrote in message
news:4860031@discussion.autodesk.com...
Good Day all.
Robert Howell
Have not tried that one but it sounds like it will do what I want. I will
take a closer look at it.
Just to clarify. The assembly shows up visually but does not show up under
the extended statistics where I should be able to edit the slope of the
catchlines.
Thanks Matt.
"Matt Kolberg" wrote in message
news:4860802@discussion.autodesk.com...
Matt Kolberg
Good Day all.
Robert Howell
Found the problem. There were additional baselines where only regions were
required. Therefore I was unable to apply station overides. Removed the
baselines and replaced with regions and now everything is working.
Hope this helps someone else.
Good Day all.
Robert Howell
Rail Community
