Civil 3D Forum
Unable to edit C3D '07 dwg
3 REPLIES 3
156 Views, 3 Replies
I am unable to edit/copy/paste a drawing that was created with Civil 3D 2007 in Civil 3D 2006. Is there a way I can convert the drawing so that I can edit it?
3 REPLIES 3
save as 2004 format to open in 2006
dave
wrote in message news:5523323@discussion.autodesk.com...
edit it?
I tried that and was unable to create a 2004 AutoCAD copy. Two time I got the 'Fatal Error' shutdown and two times nothing happened. Any more suggestions?? Thanks
alberto_go
What do you mean by editing? Do you want to make changes to any of your objects (Alignments, profile, corridor, etc information) or just edits to the line work?
If you want to make changes to your objects, then you can export that information as an XML and the import it in a different drawing using your 2006 version.
If you want to make any changes to your line work only, then you can you export the 2007 file to a plain CAD 2004 format.
Cheers!
AG
C3D 2007, SP3
Phx, AZ
Rail Community
