Civil 3D Forum
Unable to Compute Volume - Possibly Illegal Bounding Polygon
4 REPLIES 4
nloder
1795 Views, 4 Replies
I have a volume surface created from proposed and existing surfaces, and a pretty complex polygon to calculate the volume within an alternative area.
When I select Volumes-Bounded Volumes and select my volume surface, it says "Unable to Compute Volume - Possibly illegal bounding polygon."  It works with other polygons, not this one.  I have tried the following:
FLATTEN the polygon to 2D (all z's = 0)
Re-draw the polygon with one single PE command
Explode and re-join the polygon with PE-Multiple-JOIN
What else can I try?  How else can I get the volume under this specific area?
4 REPLIES 4
Sinc
in reply to: nloder
You might have duplicate vertices in your polyline.  You can try running the MapClean command, and set it to remove psuedo-nodes, and see if it helps.
Sinc
ralstogj
in reply to: nloder
Try
the Boundary command or the old -hatch command and retain the boundary.
Regards
Justin Ralston
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
dgordon
in reply to: nloder
sometimes you have to simply move vertices around ever so slighty to get it to work.
Dan
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
nloder
in reply to: dgordon
I ended up re-drawing the polygon in three smaller regions, and I was able to compute volume and just add everything together.  Hopefully it keeps working, because I have to frequently update quantities for this area.
Thanks for the responses! 🙂
Rail Community
