I am trying to create setout of the road alignment by extracting the information in the form of geomety report from UKIE combined geometry tool. I got report of most of the alignments but some alignments have no information in it.
any gusess what would be the problem?
Screen shot attached below
Solved by mattcane. Go to Solution.
i know this is an old post but i had same problem recently. i found to solution was to make sure the profile was the correct length. make sure it starts at same start station and end station not before and not after. you can extend your profile views in the profile view properties.
