I dont know if its the UCS thats twisting or something else thats happening but it is driving me crazy! If you look at the screen print i attached you can see that the view cube is ortagonal but the cursor is slightly rotated. If i restart my computer this will not be the case. Then the cursor and the view cube both will be ortagonal. But after a while, for no reason it will rotate again and I have to restart my computer! Can anyone help please!!
Solved by rkmcswain. Go to Solution.
If UCSFOLLOW didnt work, try these also
SNAPANG --> set to 0
Enter PLAN command and set to World.
One more thing to check = http://totalcad.wordpress.com/2011/03/10/follow-up-on-feeling-a-little-skewed/
