Civil 3D Forum
Two profiles views - one plan view on same sheet.
9 REPLIES 9
Message 1 of 10
485 Views, 9 Replies
Two Profiles Views - One plan on same sheet.
Currently working on plan -profile of road with ditch on each side, client want to show whole road in plan view. Then show two profile view below of each of ditches. I am stumped trying to get TWO profile view templetes (I guess this is what I am trying to say) . Thank you for any help.
9 REPLIES 9
Message 2 of 10
kcobabe
Best bet, and probably what they are asking for, is a profile of the center of the road.  All you need to do is create the center line profile then do a superimposed profile of the ditches into the center.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Message 3 of 10
kcobabe
in reply to: kcobabe
Keep in mind this means you will need 3 profiles.  You can actually delete the profile view panels after if you want to save on space and know you will never need them.  More over if you don't want the centerline profile, just create the view and turn off the centerline profile.  Just make sure they know those profiles are "Superimposed @ Center" so the can accomodate for position of the centerline and not the ditch itself.  Last thing you want is your ditch to not cover the volume the engineer designed it for in certain areas.  That would be bad.
R10 - 2020 ACAD
2014 - 2020 Revit
Infraworks
2018-2020 Inventor
2020 Navisworks
Message 4 of 10
Lisa_Pohlmeyer
As an alternative method, you can just create your LT & RT ditch profiles right on the profile view for your centerline profile.  I've attached a file that you can look at to see how they're labeled. All of the labeling shows the profile name and the flowline at the CL stationing and offset.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 5 of 10
Here is what I am trying to get too. The part showing the two profiles of the ditches. North ditch and south ditch of an existing road to show up on one sheet.
DESIREE' L. DAIGLE
225.450.1383
DDAIGLE@APGOV.US
[cid:image002.png@01D03955.69167FF0]
Message 6 of 10
Sorry the image didn't show up.
Message 7 of 10
Lisa_Pohlmeyer
Natively you can't do that in Civil 3D. You could do it manually, but it would be alot of work.
Lisa Pohlmeyer
Civil 3D User
Message 8 of 10
in reply to: Lisa_Pohlmeyer
Just my luck!
Message 9 of 10
johngordon6189
viewports.... place the two profiles in model space and create viewports over each in paperspace layout.  Not difficult.
John Gordon
CAD Manager/Survey Technician
C3D 2018/2020
Microstation
Windows 10
Message 10 of 10
kcobabe
in reply to: johngordon6189
Exactly what I was going to suggest.  Just go old school and cut the profiles.  Plan production tools make a mess of everything anyway.  Tryin to get your grid to go edge to edge is not always possible.
R10 - 2020 ACAD
2014 - 2020 Revit
Infraworks
2018-2020 Inventor
2020 Navisworks
Rail Community
