Hi all!,
I am trying to turn off some markers shown below in magenta (the circles). The problem is, I've gone through the ALignment Styles and can't seem to locate the layer that these markers are actually part of. Does anyone have any recommendations on where to look? Thank you for any help you can provide!
Option 1:
Edit the Alignment Style. In the Alignment Style dialog box, go to the Markers tab and change the Marker Styles to <None>.
Option 2:
Edit the Marker Style being used by the Alignment Style, Alignment Points you see on the Alignment Style Markers tab. In the Marker Style dialog box on the Display tab, turn off the visibility of the Marker.
I would go with option 1 as the Marker Style is a General Multipurpose Style that you may want to display elsewhere or may be in use elsewhere.
Gavin,
Thank you. I had already exhausted option 1 in my trail/errors of getting the markers to go away; however, your option two suggestion worked perfectly! Thank you so much!
Well glad that worked for you but a unclear on why option 1 did not work.
Are the Marker Styles being applied to the Alignment Style already set to <None> but you were still seing the circle marks displayed, or are you unable to set them to <None>?
Anyway, sounds like that took care of your immediate issue. Good luck with things.
Gavin,
Yeah, I don't know what was going on. I was able to set the marker styles being applied to Alignment Styles to <None>, but for some reason the magenta markers were still coming up, hence my question. I may dig around some more and trouble shoot that to see if there is a reason this was happening. I'd like to avoid it in the future 🙂 Anyway, thank you again for your help! Have a great day!
