assembly How do I turn off the magenta circles in my assembly. I found it once and can't seem to find it again..... see attachment.
Solved by dklebosky. Go to Solution.
Select the assembly, Right click and select edit assembly style.
Go to the Display tab and turn off the insertion point.
You might want to consider keeping the circle and making it smaller on the Marker tab. Note here the 'Component' dropdown list. You have setting for all of the markers/points.
John Mayo
I'm way off. I thought you meant on the assembly not the subassemblies.
I would bet that is the Standard style marker you are using. Either edit that to be smaller (Settings tab of panorama, Multipurpose styles, Markers), or change the drawing scale, or edit the Code Set Style.
John Mayo
I was able to make them small enough to effectively disappear following these steps.
Toolspace --> Settings --> General --> Multipurpose Styles --> Marker Syles --> Standard
You will need to change the "Standard" Marker Styles size to a smaller size so it doesn't show up in the cross sections. You will probably need to play around with the setting to see what works best for them.
Hope this helps
Try this
Hover your point mouse on the magenta circle that u want it to go away and wait till a rectangle tag shows up, u are looking what is in front of Point Codes. Keep it in your mind the name showing.
Next, go to Assembly Properties > Codes > On the right side of the Selected Code set style go for Edit current Selection
There you expand the "Point" option. Here you are going to look for the name that u saw when you hovered your mouse on the Circle. Now go to the Column named Style and match the Column and row of the Point Code name that u saw previously. Look for the icon right next to the name, click on it, go for Edit current selection, Display tab and turn off the Lamp that is ON just clicking on it.
Edit your Code Set Style. These markers are Point Codes, not Links, as you ask in your post title. Links are the lines that connect points.
Those are featurelines.. need to change to No Display code set style for Section View
