So, I can create expressions to truncate my northing and easting so I can display them truncated in my point tables. Does anyone know how to show the truncated northing and easting in my alignment label style? When I go to select it, my truncated northing and eastings are not choices. I can hand edit the N and E for each point, but that gets time consuming and opens up room for error.
While I'm here, why is it that labeling choices are different for alignments than they are for general labels, than they are for parcels? Why does that make any sense?
Solved by Jay_B. Go to Solution.
Solved by rl_jackson. Go to Solution.
You need to create a seperate alignment lable style just as you did for the point table with the Northing/Easting truncated as you did before, not sure if you did this with an expression or by rounding.
Rick Jackson
Survey CAD Technician VI
You need to create a separate expression for the alignment labels.
Rick Jackson
Yes, most of the categories found under Settings Tab of Toolspace > Alignment > Label Styles support expressions.
Label Sets are a collection of Styles, you need to go back a step to the style (or styles) you wish to truncate.
Below is for Geometry Points, you may have additional categories where you'll need to add the expression.
Rick Jackson
Select an existing alignment > Rt. Click > choose Edit Alignment Labels > This will display the individual styles in use for current Label Set applied to alignment.
Thanks guys: It finally dawned on me what you were saying. Works great!
I still wonder why I have to redo the same expression in several different places, but that I can live with.
Paul
paulgalli5397 wrote:I still wonder why I have to redo the same expression in several different places, but that I can live with.
I can't speak for Rick but I'll guess that he'd agree that we often wonder the same.
Glad to hear it worked out.
