Hi there,
I have a project just completed, but I want to view it exactly how it looks, cut been taken off and fill been added. Pretty much, see the exact finished construction before it is really constructed, I have tried masking some surfaces, but doesn't seem to work.
Thanks...
you can create a new surface, then you can paste existing surfaces in the order you created them. First paste the existing ground, then paste the new suface-part. Check >>>here<<< for how to paste surfaces.
- alfred -
Sorry, >>>this link<<< shows the paste-workflow.
- alfred -
Thanks so much,
It worked, but one more thing, is there any way I can differenciate colours, I have an existing surface, cut fill, flat area, and a road.
as long as the surfaces are seperated you can give them different styles.
In the one that has pasted all sub-surfaces I would not know a way to do that.
Then let's think about alternative 2:
...does that work for you?
- alfred -
