I'm intimately aware that the datum surface for the many rehab subs doesn't work. Is there a work around to get T&L numbers?
Your Name
Solved by Joe-Bouza. Go to Solution.
At this point the only work around I can come up with is to relace the OMII with an outside super and use its datum surface clipped at the widening line
Your Name
Are you trying to calculate the volume across widenings on both sides, with the central area left unchanged?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
No. Between the overlay and existing. the datum line created extends from bottom of widening to widening as if the M&O sectin was not there, and the line looks very unreliable.
Your Name
