0 Kudos
Post 1 of 4
Trouble with double click customization
206 Views, 3 Replies
05-27-2013 01:55 PM
I have altered my CUI so when I double click on civil 3d objects it opens up their properties for quick editing. Never had a problem pre 2013 and I am sure this is something I did but am lost.
Every time I double click on any object it just opens up the properties box. It skips right over my double click customization.
Thanks in advance.
Regards
Rob
Hi Rob,
Please make sure that Object Name under Advanced Properties for the double click action is set to the particular object type associated with the command that you are trying to use, as this image shows.
You can find this information if you do LIST.
266 Kudos
Post 2 of 4
Re: Trouble with double click customization
05-27-2013 03:02 PM in reply to: rob.howell
Which CUI file are you editing? Is it possible that another CUI file has the double click action set to the AutoCAD properties?
Just thinking out loud here.
Brian Hailey
CAD-1.com
My Blog
0 Kudos
Post 3 of 4
05-28-2013 09:03 AM in reply to: BrianHailey
Good day Brian,
It is the Civil CUI that I am editing. It was working just a couple of weeks ago but now all I get is the properties box when I double click on any object that has double click functionality assigned. Needless to say this is very frustrating.
8 Kudos
Post 4 of 4
05-29-2013 04:18 PM in reply to: rob.howell
Hi Rob,
Tatiana Machado
AEC-ENI Application Engineer
