ok. changed it. lost all civil tool pallette pull downs. should i try to reset profiles?
Yes. Do that. If you hadn't said the program was just reinstalled. I'd say that would be the next step.
What Workspace do you have set?
You can also type WORKSPACE on the command line and then ?.
Allen
Allen Jessup
CAD Manager - Designer
it says civil complete even though no pallettes work. i also have survey & topo, design and some others.
I'll have to think about this. In the mean time. Try starting Civil 3D through the Start menu.
Allen
Allen Jessup
I've been out of work. So I haven't thought about it much. But....
Can you log on as a different users and see if the trouble persists?
If you can access the commands under a different user name THIS might help you. If you aren't comfortable editing the registry. Ask your IT to help.
Allen
Allen Jessup
I will put in a help desk. not sure how fast they will get it done.
I just rebooted my computer and started civil 3d.and i saw this while it was loading.
Initializing........
C:\Program Files (x86)\AutoCAD Civil 3D 2009\AcMapWorkspace.arx cannot find a
dll or other file that it needs.
C:\Program Files (x86)\AutoCAD Civil 3D 2009\AcMapDwfApi.arx cannot find a dll
Failed.
AcMapWorkspace.arx Load Failed
AcMapDwfApi.arx Load Failed
C:\Program Files (x86)\AutoCAD Civil 3D 2009\AcMapDwfUI.arx cannot find a dll
C:\Program Files (x86)\AutoCAD Civil 3D 2009\Civil\AeccUiModel.arx cannot find
a dll or other file that it needs.
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD menu utilities loaded.
Command: _RIBBON
Command: COMMANDLINE
While they're there. You might as well have them run a Repair on Cvil 3D.
Allen
Allen Jessup
ok. i'll get that done. this is very frustrating. it guy is hospital for a week or more so i'll have to work around it until then. thanks
I understand the frustration. It's difficult to diagnose this from a distance. I think the real issue is - Why are you getting fatal errors? If it's a new computer. I'm assuming that it's 64 bit. It may be that Civil 3D 2009, as a 32 bit program, has trouble with the 64 bit OS. What are the spec's on your computer?
Just something to mention in regards to this. Something you might want to inform your bosses about. I'm thinking that you're not on subscription since you're still on 2009.
As of Feb 1 2005 Autodesk will no longer offer upgrade options from non-current software. After February 1, 2015 you will lose all equity in your expired licenses. This upgrade policy change will not affect licenses that are currently on subscription. Also, for a limited time only, Autodesk is offering a Buy One, Get One Free promotion on eligible Autodesk product upgrades from versions R14 to 2007 until Jan 24 2014.
What this means is that after Feb 1, 2015 you'll have to pay full price to upgrade to a current version of Civil 3D. It may be time to upgrade to a 64 bit version of the software. Just a thought.
Allen
Allen Jessup
