Joe-Bouza
Message 1 of 9 (224 Views)
trouble exporting to plain autocad
224 Views, 8 Replies
06-28-2012 02:46 PM
If I audit or recover this file I get no errors, but if I try to export or batch and explode aec object I get error...try recover and no file gets created. Any suggestions?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
tcorey
Message 2 of 9 (216 Views)
Re: trouble exporting to plain autocad
06-28-2012 04:36 PM in reply to: Joe-Bouza
Hi Joe,
Can you Exportotautocadr12dxf? I usually go to this format as a standby when nothing else works. Maybe it will work for you.
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Joe-Bouza
Message 3 of 9 (204 Views)
06-28-2012 07:03 PM in reply to: tcorey
Hi Tim
Thanks, that should work, I'll give it a go in the morning
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Active Contributor
cfiorica
Message 4 of 9 (196 Views)
06-28-2012 10:41 PM in reply to: Joe-Bouza
This happens to me too.  I do not want a DXF file, I would like to export to AutoCAD like it's supposed to.
Carl M. Fiorica, P.E., LEED A.P.
Burkett and Wong Engineers
3434 4th Ave
San Diego, CA 92103
neilyj
Message 5 of 9 (190 Views)
06-29-2012 02:31 AM in reply to: Joe-Bouza
I've had issues when XREF's are in the drawing.
I do a SAVEAS, BIND the Xrefs and EXPORT then CLOSE the drawing without Saving - seems to work
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Joe-Bouza
Message 6 of 9 (182 Views)
06-29-2012 06:19 AM in reply to: neilyj
I'm still having trouble, I don't have xrefs but do have datalinks that cannot be bound, detached  or unloaded? I thimks I PDF is my only option
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
neilyj
Message 7 of 9 (171 Views)
06-29-2012 06:51 AM in reply to: Joe-Bouza
What about DWF ??
If you are wanting to use as an underlay, I have had much better results with a DWF rather than a pdf
neilyj
jmayo
Message 8 of 9 (167 Views)
06-29-2012 07:36 AM in reply to: Joe-Bouza
I agree with that Neil. Popping a pdf into a dwg is the best way I know to make AutoCAD slow to a crawl.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Joe-Bouza
Message 9 of 9 (162 Views)
06-29-2012 08:48 AM in reply to: jmayo
Dwf, PDF, it make no diff to me I'm sending the drawing out.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
