Am struggling to pull off some corridor but the standard daylight subassembly is letting me down. It mulfunctions when I connect it to the Generic Linktoslope subassembly. In some Areas it works fine but in others it doesn't. My plan is to apply a ditch at the point where the LinktoSlope meets the ground level and to have this ditch again daylight back to the target surface.
any suggestions will be appreciated
This subassembly is confirmed defective:
Use DaylightGeneral instead. It's a little more complex but doesn't have the same issue as DaylightStandard.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
