Civil 3D Forum
Trouble Consistantly Daylighting from SubAssembly to Alignment Target
3 REPLIES 3
L3GO-Ed
5432 Views, 3 Replies
Am struggling to pull off some corridor but the standard daylight subassembly is letting me down. It mulfunctions when I connect it to the Generic Linktoslope subassembly. In some Areas it works fine but in others it doesn't. My plan is to apply a ditch at the point where the LinktoSlope meets the ground level and to have this ditch again daylight back to the target surface.
any suggestions will be appreciated
3 REPLIES 3
fcernst
in reply to: L3GO-Ed
This subassembly is confirmed defective:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Confirmed-Defect-Daylight-Standard/m-p/430207...
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
sboon
Use DaylightGeneral instead.  It's a little more complex but doesn't have the same issue as DaylightStandard.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
L3GO-Ed
ehwu, atleast this clears it. So i need to think of another subassembly. thanx for the replies guys
Rail Community
