Civil 3D Forum
Trimble Link Icons
1 REPLY 1
jtuzyk
647 Views, 1 Reply
Trimble Link Icons
Can anyone explain to me how to get the icons to show up with Trimble Link??
1 REPLY 1
Alfred.NESWADBA
in reply to: jtuzyk
if you know how the menu-file is named and where it is place (could not look for it, because I have not installed the Trimble-options) you could look for a file that has the same name like the menu, but the extension MNR.
To get the name of the menu you could look into the command _MENULOAD or with _CUI (and partial menues). They are normally placed in the directory (for Win7):
C:\Users\<YourUserName>\AppData\Roaming\Autodesk\C3D 2012\deu\Support
If you found the MNR-file:
  • close AutoCAD/Civil3D
  • rename the MNR-file to any other extions or move it to another directory (so for Civil it look like erased, but for you it's saved)
  • start AutoCAD/Civil3D ==> this file will be generated when Civil loads the drawing ... and so the icons are refreshed (hopefully)
If that does not help the second chance will be:
  • log in to your windows with another user-account
  • start Civil3D ==> look if the icons are ok
  • if so, look within this user-directory, search for these menu-files (in this user-directory),
  • copy the CUIX and MNR to a temporary directory
  • log out and log in with you original user-account
  • copy the CUIX and MNR from the temp-folder to your user-directory
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Rail Community
