Civil 3D Forum
Trimble Link C3D2011 Install Problem
30 REPLIES 30
Message 1 of 31
2210 Views, 30 Replies
Hi, can someone help me please,
I'm trying to intall trimble link for civil 3d 2011 and it says it cannot find civil 3d or It is not installed in the system.
why?
System:
Windows7 x64
Civil 3d 2011 x64
30 REPLIES 30
Message 21 of 31
Sinc
> {quote:title=Guest wrote:}{quote}
> The only solution would be a XP mode version of Civil 3d in 32bit
> environment for trimble link connectivity.
ACK!
I hope nobody is seriously floating that as a solution.
Was Trimble Link created in C++, then? If they had created it in a .NET language, then they shouldn't have a problem, except for the installer. But if it was created in C++, then it can take more effort to make a 64-bit version, depending on how well the original source code was written. In either case, it should be possible to create a 64-bit version.
-- Sinc
http://www.ejsurveying.com
http://www.quuxsoft.com
Sinc
Message 22 of 31
I think it's all ok now
theres a 64bit trimble link.
http://www.trimble.com/link_ts.asp?Nav=Collection-63438
Message 23 of 31
Is this working for anyone with 64-bit W7? We get the message "Required AutoCAD Civil 3D 2011 or AutoCAD Civil 2011 System not found"
Message 24 of 31
DarrenP
worked fine here win 7 ultimate 64 bit civil 3d 2011 64 bit
nevermind when i closed civil 3d and opened it back up the trimble tab disappered
i even uninstalled it and reinstalled it
this is strange
Edited by: DarrenP on May 4, 2010 12:00 PM
Edited by: DarrenP on May 4, 2010 12:15 PM Edited by: DarrenP on May 4, 2010 12:22 PM
DarrenP
Message 25 of 31
egoetz3
Same here.......No luck. The new Trimble Link for 64 Bit is showing the same error message; can't find the 64 Bit intallation of Civil 3D. Notice the screen capture showing the installation error message over an open session of Civil 3D. Dope!!!
Message 26 of 31
Buzz12345
Same here - getting the message "Required AutoCAD Civil 3D 2011 or AutoCAD Civil 2011 System not found"
Michael
Win 7 64 bit
Civil3d 2011 (& 2010 & even 2009 for LDT) Edited by: Buzz123 on May 5, 2010 2:48 PM
Michael
AEC Collection - Civil3D 2023 & Infraworks 2023
www.foxsurvey.co.nz
Message 27 of 31
DarrenP
did you try running the .exe as an administrator?
i didn't run into this problem on win 7 64 bit
DarrenP
Message 28 of 31
It's still not working 100% correctly. Trimble Support is aware of this
issue. We will provide an update when it is up and running as it should.
Jason Hickey
Autodesk Product Support
http://beingcivil.typepad.com
Message 29 of 31
Buzz12345
There's a new version at the Trimble website (http://www.trimble.com/link_ts.asp?Nav=Collection-63438) that completes the install successfully - and then Trimble link appears on the ribbon. Fantastic.
You know, this has been a pretty quick response. I recall waiting months for Trimble Link updates in years past. So to get an update and then the revisions so quick is great. It appears that Autodesk took an active interest in monitoring this at the very least.
So, thanks Autodesk. Thanks Trimble.
Michael
Win 7 64-bit
Michael
www.foxsurvey.co.nz
Message 30 of 31
> Michael
> Win 7 64-bit
Thanks for the patience - working with them, they were able to track
down the problem last night. Kudos to Trimble software engineering for
getting an updated installer up so fast and kudos to Trimble support for
working so closely and keeping us up to date!
Jason Hickey
Message 31 of 31
I switched to 2011.  I have the Trimble Link tab in the ribbon.  When I try to export a surface file it crashes C3D.  I've tried uninstalling and reinstalling TL.  No help.  I have 64b W7 and C3D.  The Trimble download said it was for 32 and 64 bit.  Any ideas?
Rail Community
