Trimble Access, Civil 3d 2012 export road problem
when I export a road file to my TS2 it becomes corrupted (file size 50% of what it should be.
4 months ago there was no problem. The weird thing a is that the other worstation in the office has this issue to.
Here's what I have done to troubleshoot:
I can rule out the following.
Both machines are identical:
Pentium Zeon
16 gb RAM
Identical software installation
Anyone have any ideas?
Marty
The rxl file includes the alignment, profile and cross section data from your corridor. The section data you get is dependent on the configuration of your corridor at the time of export. If the frequency settings have changed or the corridor surface is not available then the section data may be significantly different than previous.
RXL files are just text, almost exactly the same as an XML file so you can open them with Notepad and examine the data.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Thank-you Matt and Steve, I apolagize for not getting back to you sooner, I was out of the office on Friday.
Both of your suggestions were excelent and I will use to further investigate it today. I will post again when I get it resolved.
Marty
