I need to create a triangular grid of injection boreholes with side lengths of 2m and can't think of a slick way to do it.
I've created two linear arrays of polyline at the correct spacings and MAPCLEANed to break all the crossing lines so I now have line segments at the correct locations.I now need to put a point at each vertex to show the locations of the holes.
I'm sure there must be a better way of doing this - just thinking while typing: if the two array are on different layers, I could JOIN the polys on each layer and then add POINTS at vertices??
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by tcorey. Go to Solution.
Solved by sboon. Go to Solution.
No need to apologise - but it was the OSNAPS that seemed to be the problem.
Attached has no OSNAPS active
