Valued Contributor
rachelc11
Message 11 of 15 (264 Views)
Re: Triangles not Seeing Breaklines
04-17-2012 09:14 AM in reply to: rachelc11
Aha. Didn't know about the boundary thing either. I typicall re-add a boundary at least a dozen times before I can finish a surface. Good to know...
TRogers
Message 12 of 15 (264 Views)
I'm so glad that the OOPS command is still active and someone actually uses it!!  Let's hope it never get retired.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Sinc
Message 13 of 15 (244 Views)
04-17-2012 03:26 PM in reply to: rachelc11
Yes, it would be nice if there were a way to force boundaries to always be at the bottom of the list.  This is a suggestion I've made to Autodesk, but it hasn't happened yet (I keep hoping).  Adding breaklines after adding a boundary can lead to some very bizarre behavior in your Surface, until you sort out the order of operations.
Sinc
robert.thomson
Message 14 of 15 (210 Views)
08-17-2012 09:45 AM in reply to: AllenJessup
My breakline operation was at the bottom of the list.  Moving it to the top solved my problem.  This is one good piece of info I was not aware of and may solve many of the problems I've had with surfaces.
THANKS!
AllenJessup
Message 15 of 15 (170 Views)
08-20-2012 04:54 AM in reply to: robert.thomson
I learn from these groups and then pass it on. Glad it helped.
Allen
