Valued Contributor
rachelc11
Message 1 of 15 (524 Views)
Triangles not Seeing Breaklines
524 Views, 14 Replies
04-17-2012 08:30 AM
Hello, this has been driving me crazy lately. (see picture) Putting in a simple berm crest, and the triangles skip right over a certain section. Swap edge does nothing to help and adding points seems to make things worse. I have been able to fix this problem before, but only by deleting my surface and then putting all the pieces back in at once. Then it's perfect. Is there an easier way? I think part of the problem may be that the "Contour help" I put in at the blue major contours is screwing things up.I have had the same issue when putting in down-slope channels as well.
Thanks!
In the Surface Properties dialog box, on the Definition tab, try moving the operation that added those breaklines to the bottom of the list in the lower pane using the arrows on the left.
Allen
TRogers
Message 2 of 15 (517 Views)
Re: Triangles not Seeing Breaklines
04-17-2012 08:53 AM in reply to: rachelc11
Have you added any breaklines?
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Valued Contributor
rachelc11
Message 3 of 15 (510 Views)
04-17-2012 08:55 AM in reply to: TRogers
Yes, in the picture the magenta lines and the daylight line (edge of blue contours) are breaklines.
TRogers
Message 4 of 15 (503 Views)
04-17-2012 08:57 AM in reply to: rachelc11
I'm not seeing the problem.  If the blue lines are your breaklines, it's doing what it is suppose to.
*Civil 3DJ*
Todd Rogers
Visit my blog here.
AllenJessup
Message 5 of 15 (500 Views)
04-17-2012 09:00 AM in reply to: rachelc11
Allen
Valued Mentor
owenmull
Message 6 of 15 (497 Views)
04-17-2012 09:03 AM in reply to: rachelc11
This appears to be a design surface you are creating.
You added your points, but you need to add in your breaklines as well.
Go to your Surface-->Definiton-->Breaklines-->Right Click-->Add
Give it a name, and go thru and select all the breaklines, then hit Enter. They now should be a part of your Surface.
Add Breaklines to Surface
-Owen
Windows 7 x 64 bit
NVidia Quadro K3000M Dual Monitor
32.0 GB RAM
Intel Core i7-3820QM @ 2.70 GHz
Civil 3D 2013 SP 2
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
Valued Contributor
rachelc11
Message 7 of 15 (493 Views)
04-17-2012 09:05 AM in reply to: AllenJessup
I believe this is solution I need. I did not realize that the order in which you add the breaklines mattered much at all. Thanks.
Valued Mentor
owenmull
Message 8 of 15 (489 Views)
04-17-2012 09:06 AM in reply to: rachelc11
If the blue lines are your breaklines, and the cyan lines are the surface contours, then this surface is doing exactly what it is supposed to.
If that is the case, look: your surface IS traingulating to the blue breaklines.
This looks right to me, I don't know what it is that would be wrong then.
-Owen
Windows 7 x 64 bit
32.0 GB RAM
Civil 3D 2013 SP 2
Valued Contributor
rachelc11
Message 9 of 15 (485 Views)
04-17-2012 09:08 AM in reply to: rachelc11
Nope, blue are major contours, cyan minor. Magenta and white are breaks, which had already been aded to surface.
AllenJessup
Message 10 of 15 (481 Views)
04-17-2012 09:12 AM in reply to: rachelc11
I didn't either until recently. I knew if I erased the lines, oops'd them back in and added them to the Surface again it would work. A couple of weeks ago JohnM showed me how this could be done using the list in Surface Properties. This is also why outer boundaries go hay-wire. They need to be at the bottom of the list.
Allen
