Civil 3D Forum
Triangles not Seeing Breaklines
14 REPLIES 14
Message 1 of 15
802 Views, 14 Replies
Hello, this has been driving me crazy lately. (see picture) Putting in a simple berm crest, and the triangles skip right over a certain section. Swap edge does nothing to help and adding points seems to make things worse. I have been able to fix this problem before, but only by deleting my surface and then putting all the pieces back in at once. Then it's perfect. Is there an easier way? I think part of the problem may be that the "Contour help" I put in at the blue major contours is screwing things up.I have had the same issue when putting in down-slope channels as well.
Thanks!
14 REPLIES 14
Message 2 of 15
ToddRogers-WPM
Have you added any breaklines?
Todd Rogers
Message 3 of 15
in reply to: ToddRogers-WPM
Yes, in the picture the magenta lines and the daylight line (edge of blue contours) are breaklines.
Message 4 of 15
ToddRogers-WPM
I'm not seeing the problem.  If the blue lines are your breaklines, it's doing what it is suppose to.
Todd Rogers
Message 5 of 15
AllenJessup
In the Surface Properties dialog box, on the Definition tab, try moving the operation that added those breaklines to the bottom of the list in the lower pane using the arrows on the left.
Allen
Allen Jessup
CAD Manager - Designer
Message 6 of 15
This appears to be a design surface you are creating.
You added your points, but you need to add in your breaklines as well.
Go to your Surface-->Definiton-->Breaklines-->Right Click-->Add
Give it a name, and go thru and select all the breaklines, then hit Enter. They now should be a part of your Surface.
Add Breaklines to Surface
Message 7 of 15
in reply to: AllenJessup
I believe this is solution I need. I did not realize that the order in which you add the breaklines mattered much at all. Thanks.
Message 8 of 15
If the blue lines are your breaklines, and the cyan lines are the surface contours, then this surface is doing exactly what it is supposed to.
If that is the case, look: your surface IS traingulating to the blue breaklines.
This looks right to me, I don't know what it is that would be wrong then.
Message 9 of 15
Nope, blue are major contours, cyan minor. Magenta and white are breaks, which had already been aded to surface.
Message 10 of 15
AllenJessup
I didn't either until recently. I knew if I erased the lines, oops'd them back in and added them to the Surface again it would work. A couple of weeks ago JohnM showed me how this could be done using the list in Surface Properties. This is also why outer boundaries go hay-wire. They need to be at the bottom of the list.
Allen
Allen Jessup
Message 11 of 15
Aha. Didn't know about the boundary thing either. I typicall re-add a boundary at least a dozen times before I can finish a surface. Good to know...
Message 12 of 15
ToddRogers-WPM
I'm so glad that the OOPS command is still active and someone actually uses it!!  Let's hope it never get retired.
Todd Rogers
Message 13 of 15
Sinc
Yes, it would be nice if there were a way to force boundaries to always be at the bottom of the list.  This is a suggestion I've made to Autodesk, but it hasn't happened yet (I keep hoping).  Adding breaklines after adding a boundary can lead to some very bizarre behavior in your Surface, until you sort out the order of operations.
Sinc
Message 14 of 15
My breakline operation was at the bottom of the list.  Moving it to the top solved my problem.  This is one good piece of info I was not aware of and may solve many of the problems I've had with surfaces.
THANKS!
Message 15 of 15
I learn from these groups and then pass it on. Glad it helped.
Allen
Allen Jessup
Rail Community
