I have downloaded the Autocad Civil 3D 2015 Trial on Windows 8. It installed completely. When i started it, the trial login page failed with a script error.
See attached PDF.
kindly help.
I am having the exact same issue this morning with the Revit LT 2015 trial on Windows 7, see attached.
Thanks for reporting this one! We are currently looking into the root cause and will provide a status update once available.
I'm having the same issues. Here is what the message says
Line: 91
Char: 4
Error: Unable to get property "toUpperCase' of undefined or null reference
Code: 0
URL: http://ipm.autodesk.com/ipm/common/scripts/2015/sso/validate-login.js
I've tried updateding my Internet Explorer. I've tried creating a new login. I've tried disableing the error messages in Interner Explorer. I've tried lowering the security level in Internet Explorer. I've also tried to reinstall Revit and can't get it to work. Hope this helps.
This one should be resolved now. Can everyone confirm that it's no longer showing on your end?
I'm still getting the same error message. Do I have to download and reinstall the Trial version?
I'm also having trouble using the online trial. I'm getting this page when I try to open Revit. See attached.
Looks like I jumped the gun... our dev team is aware that this is still occurring and working on it.
*Edit* Just confirmed that this has been fixed.
Working now. Both Trial and online Trial. Thank you guys for getting this issure resolved.
Hi!
Similar problem with Civil 3D 2016 TRIAL.
Problem is within this script:
http://ipm.autodesk.com/ipm/common/scripts/2016/baseline-treatment.js
Please take a look at the attached image...
I'm running in the same problem. Script Error for AutoCAD LT trial version. Please advise!
Thank you!
Problem is on Autodesk side (it's a web script).
Try to disconnect your internet connection before starting the program.
You can turn the connenction back on, once the program is running.
Thank you! It's working now. After I shut down my computer overnight again and tried to open it again today - it's finally working.
Whenever I open up the trial for 3ds max, I cant paste anything into the activation code. Is their a fix? btw im using 3ds max 2013.
