We have lost the use of the two transparent commands 'spe and 'sse. When I either click on the toolbar or type 'spe or '_spe in the middle of a command, they don't work like the other transparent commands. When I click on toolbar by itself, I get an error "Unknown comment "SPE". The other transparent commands say something like "PSE must be called from within another command". Any suggestions?
Also, is the actual comment 'spe the command name or is it an alias. I was thinking that if I knew the command name, I could create another allias as a work around.
This is happending on multiple computers.
Solved by BrianHailey. Go to Solution.
As far as I know, those are the command names. Typically when you hover over a tool the tooltip will give you the full command name. When I hover over those tools, this is what I see:
Perhaps the command became undefined somehow? Try the REDEFINE command.
Do other transparent commands work or is it limited to these two commands?
Just for grins, make sure QAFLAGS = 0, also.
