Civil 3D Forum
Transparency in rendering
12 REPLIES 12
Message 1 of 13
3604 Views, 12 Replies
Good day all,
I just have some 3d objects, I just want to make some of them transparent when I do the rendering. I've tried opacity and it shows transparent abjects on screen but when I do the render it is not. Any body cqn help?
12 REPLIES 12
Message 2 of 13
Alfred.NESWADBA
what version of Civil3D do you speak about?
And in most cases (as rendering- and material-settings are quite complex) it might help to upload a drawing with some of the objects to see your complete material definitions and environment settings.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 13
in reply to: Alfred.NESWADBA
Hi, I am using 2013 version. I attached the .dwg file.
Here is the link:
http://www.attachmore.com/792611473
Regards.
Message 4 of 13
Alfred.NESWADBA
>> I've tried opacity
You mean the "opacity in visual styles"? If I'm right with that: you should not get confused by visual styles (where you set the opacity to 50%) in opposite to output of command _RENDER. Visual styles are just for the display in AutoCAD's graphics window, it is irrelevant for rendering. The transparency of objects is only defined by the material-definition (and may be the environment- and rendering-options you set).
But just to make sure, my rendering output (directly from your drawing) is that:
And it is transparent (as e.g. you see the wheel on the backside). So I'm not really sure to understand the question correct.
- alfred -
Alfred NESWADBA
Message 5 of 13
Yes, you are right. but I need make it more transparent. i need to see the equipments positioned onder the track. and I do not know how to do that. i need something like the attched image.
Message 6 of 13
Alfred.NESWADBA
then chose a material (or create a new one) that is more transparent.
You have attached the material "Transparent Clear" to the layer "truck body", try to assign a new material, based on "Default Generic", because there you have a most individual properties you can adjust.
See the screenshot with such a material, you see the slider to adjust the transparency to your special needs.
HTH, good luck, - alfred -
Alfred NESWADBA
Message 7 of 13
It is working, thank you so much. Can you give me some website addresses regarding to rendering, materials and lighting tutorials?
Message 8 of 13
Alfred.NESWADBA
Glad to know it works now for you! Thank you for your feedback.
Sorry I don't know any sites around rendering with AutoCAD. I would have to search with Google (or any other search engine) too. 😉
- alfred -
Alfred NESWADBA
Message 9 of 13
dgorsman
The basic concepts are the same, regardless of software.  I've found a few beginner books on 3DS MAX to be helpful.  Just ignore the application specific stuff and focus on lighting, materials, camera position, lens length, and the like.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 10 of 13
in reply to: dgorsman
Awesome, How can I fine them? would you please attache them here?
Message 11 of 13
dgorsman
Kind of a violation of copyright to attach books.  A simple web search for 3DS MAX books should turn up candidates, as would strolling through a book store - its one of the more common subjects.
Message 12 of 13
Alfred.NESWADBA
as Mental Ray is the basic technology >>>this link<<< might be a start, at least for search phrases 😉
- alfred -
Alfred NESWADBA
Message 13 of 13
Tanks Alfered.
Rail Community
