I am 90% into the design of a subdivision and the survey was just updated. The original design was in an arbitrary coordinate system, and the new boundary is in state plane coordinates. I would like to move all of the design information to the new boundary. This would include all of the surfaces (approximately 6).
When I move the surface (any surface), I end up with errors. If I move the surface alone, I cannot move the defining feature lines. If I move the featurlines, I loose all of the edits I have made to the surface.
Is there any clean way to translate a drawing, including all design work, to a new coordinate?
Steve
The only problem with that is that all of the edits are lost, at least when I have done it. Is there a way to preserve the edits?
Steve
Mark Green
Working on Civil 3D in Canada
You move the objects or the surface not both.
I typically prefer to move the defining objects. Once you rebuild the surface will follow.
You can also move the surface and sometimes this is good but don't move the defining objects and the surface. This will double the operation.
John Mayo
