I am trying to rotate a database through translate survey database and after I input all of my info (rotation basepoint etc.) it is rotating all of the points no where near where they are suppose to be. I was experimenting with the command a bit using various rotation angles, and it seemed to work at first, but I got out of my drawing without saving and got back in and I tried to do it again using the same rotation base point etc. (the correct way that I knew had worked at one point during my experimenting) and the location of the points are all out of whack now. Did I do something unintentionally to the points or do I maybe have to re-import the fieldbook? This has happened to me before and I am not quite sure what's going on......thanks.
I thought not saving the drawing would be a safe way to not save any of my translating....
Solved by rl_jackson. Go to Solution.
Rick Jackson
Survey CAD Technician VI
thank you for clarifying this for me. I now understand the database better. I was under the impression that I could do whatever I wanted to the points and as long as I did not save drawing, the point edits would not change.
