Civil 3D Forum
transition from one template/aasembly to another template
1 REPLY 1
eric_apostol
297 Views, 1 Reply
Hi all,
This might be asked several times already and I am just having problem to find them over here in the forum or over the internet. But my question is, is there a way to create a corridor that has a transition from one template/assembly to another template?
To make my task simple to explain, I am asked to create a swale/channel design that Ch 1-15m, it has a "V" shape and on Ch 20-30m is a "U" shape or rectangular shape. And I want to have the transition from Ch 15-20m.
I created two assmbly/template (a V shape and a U shape assembly) and tried to assigned point code to the point (on the sub assembly) I want the feature line to be linked/connected. But it is only giving me a gap on the corridor.
TL  *          * TR                                                         TL *          * TR
          * BL & TR (OVERLAPPED)                            BL*********BR
I know if I will create a surface from this, it will be connected. But this will be just alright if my alignment is straight. But in my case, my channel have horizontal curves.
Any ideas or workaround out there?
I am using a Civil 3D 2012
Thank you,
Eric
1 REPLY 1
BrianHailey
in reply to: eric_apostol
Generic links in the assembly to build the swale and offset alignments that widen along the alignment. Have the links target the offset alignments and it should get you what you want (if I read your request correctly).
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Rail Community
